4:55 pm
September 19, 2012
Probably a combination of having to reset it's almanac settings due to the distance from your last position, and not getting a steady connection to any fixed set of satellites. When you're walking, especially if there's tree cover, the access to satellites is constantly changing, and it can't get a lock on enough of them. It may have been an issue where if you had just stood still in an open position for 5 minutes it might have made enough connections. That's a long stop when you're out walking though!
BarryG said
The is the first time this has ever happened with my 710. I set out on a hike today and the 710 absolutely refused to connect to the satellite. The map displayed my home location (100 miles away) and the elevation showed my home elevation (off by 2200ft). I turned it on/off several times during the hike but no luck. When I later drove home, it connected fine.
Any ideas?
TIA
(sorry for the typo "719" in subject line but the forum s/w doesn't allow me to edit/correct it)
Barry,
This situation should not occur. Just for the heck of it "reinstall your firmware". If this does not solve your problem please let us know.
JG Technical Support is part of Jungle Ghost Enterprises (JGE) in Wayne, NJ. JG created JGE in 2007 specifically as a Repair and Service Center Worldwide for Magellan Triton and the New Explorist X10 units. For the record, JG received his moniker from the Kachins in Burma. In Burmese he is "Dua Ma Rung".
9:54 pm
I have had something similar happen when I drove to northern Maine with my 710 shut off.
The last place it was turned on was in Rhode Island so it showed that spot in R.I. when I turned it on.
I put it on a picnic table for about 30 minutes while unpacking so I'm not sure how long it took to lock on, but it had connected by the time I looked at it again.
5:04 pm
June 29, 2012
Any ideas?
TIA
