USB Socket Loose – Electrical Circuit Broken | General 510 610 710 | Forums
October 11, 2011
3:30 am
4336sp_Permalink sp_Print
When I have the cable connected for uploading from the PC, it sometimes just falls out from the bottom of the GPS. I was wondering if I should expand the connector on the cable so that it forms a tighter fit?
This is a separate issue, the snugness of the fit of the USB socket and the USB plug (cord). With many connections/disconnections of the USB cord the snugness reduces and I have had the USB cord just dropout, I had wondered whether the angle of the socket was an attempt to prevent this from happening. But in doing so has caused the USD cord to exert too much force on the USB socket.
This thread is about the USB socket moving back and forth and interrupting the electrical connection.
October 8, 2011
11:06 pm
4329sp_Permalink sp_Print
I noticed that the socket was getting loose on my 610 ages ago. I just am now very careful whenever I put the cable in - ie I try not to wiggle it around to get it in.
October 6, 2011
8:33 pm
Lucky-Lizard
Forum Posts: 19
September 12, 2011
4318sp_Permalink sp_Print
Now that's amazing service right there! :cheer:
October 3, 2011
10:35 am
4310sp_Permalink sp_Print
Graham,
I sent you a private message, but I never got a reply. However, Eric at Magellan wants to know if you would trade him your eX710 with the loose USB connector for a new unit. He would like to have the unit in order that they can see what is going on with the USB connector. If you're interested, please let me know. You can email me at [email protected].
Later,
David,
I have sent you a PM and email, happy to help in anyway.
October 3, 2011
5:31 am
4309sp_Permalink sp_Print
ShortcutHicksy wrote:
The USB socket on my 710 has become loose and this is causing the electrical connection to the printed circuit board to be intermittent. I have to move the USB cord around to locate a position where the electrical connection works. I will contact Magellan for repair. 🙁
Has anyone else experiencing this or noticed the USB socket is loose in their unit. It maybe worth check as my 710 is only 10 months old.
Graham,
Later,
September 27, 2011
11:06 am
Forum Posts: 251
4301sp_Permalink sp_Print
My socket is loose too. But has still full electrical cantact. I'm gonna try hotglue.
September 27, 2011
9:57 am
4300sp_Permalink sp_Print
Hi Phil,
It is definitely the socket; I have tried a number of different USB cords.
With the unit facing you, if you move the USB socket/cord towards the back, the electrical connection is broken. Move the USB socket/cord to the front of the unit and the electrical connection returns.
The USB socket moves in a vertical plane between the front and back of the unit (not in or out of the unit) and with my unit the electrical connect is now only there when the socket/cord is held towards the front of the unit.
September 27, 2011
9:26 am
4299sp_Permalink sp_Print
My socket is still good but I broke a cable plug that I used with my 710.
I had to wiggle it to get a connection.
If you haven't yet, try another cable to make sure it's the socket and not your cable that's broken.
The first thing I noticed and complained about was the socket at an angle, it's a stupid design flaw that makes it very easy to damage the socket or cable plug.
Plus the cable has to be unplugged to mount or dismount the unit from a Magellan mount!
When I have it connected to the computer I have it on a mount attached to my desk to prevent the cable plug from resting on the desk and applying pressure to the socket.
September 27, 2011
8:14 am
Guest(s) 1
