Severeal questions about eX310 | General 510 610 710 | Forums
February 5, 2012
1:11 pm
Paganel
Forum Posts: 116
5237sp_Permalink sp_Print
VPom wrote:
The little man - it is "Active track record is enabled." After you save the active track - record off. The man disappears. Record should re-enable - "Start".
Unfortunaly, ex310 too simple device and it is not possible to store multiple profiles and switch between them. Also, there is no route planning functions ...
310 is designed for off-road navigation. I have not seen the maps with routing the footpaths in the woods. Wherever we go, there are no roads or footpaths. We pave your route yourself.
Travel by road is better to buy a separate car navigator. In our country it costs less than $ 100. Each device must do that for which it is intended.
February 2, 2012
9:30 am
VPom
Forum Posts: 8
January 29, 2012
5206sp_Permalink sp_Print
Thanks for the all answers.
//Cheers, Victor
February 1, 2012
2:28 pm
5197sp_Permalink sp_Print
I assume the 310 is the same as higher numbered unit with regards the walk man icon. The icon is only seen when you are in GoTo mode i.e. you are routing to a cache or waypoint.
In setting you may have ‘Route Options’ and depending on how’ Routing Method’ is set, will decide which setting in APPAtlas.ini are used. Change the profile to vehicle or bike etc will also decide which setting in APPAtlas.ini are used.
I’m sure someone on the forum with a 310 will confirm this.
February 1, 2012
1:22 pm
lostnfound
Forum Posts: 14
October 15, 2011
5196sp_Permalink sp_Print
Hi VPom,
The little man is confusing. I have no idea why he is there. As for the modes there are setting or screen options that you can set for various profiles like geocaching, hiking and so on. You set up the options you want on various screens in the settings menu and save it to a particular profile. That way if you are caching and wish for different options than hiking the unit will display them when you choose the geocaching profile. For instance you might use bearing and heading for hiking. You might use bearing and heading and distance to go for geocaching. As for the car mode these settings are done by ground speed I would imagine, but that is just a guess. My best advise would be to learn by just testing the various settings and having fun with the unit. I know this is not the reply you were hoping for. I use my unit for hunting and marking my stand locations, and trails. I do some caching with the Family too.
Bill
January 31, 2012
8:03 am
VPom
Forum Posts: 8
January 29, 2012
1. There is the icon of running man at the right upper corner of the screen - what does it means? Manual describes it as "Mode" without any without detailed comments. What "Mode" meaning?
2. There are range of settings in the file APPAtlas.ini. In particular:
VehicleNavUseStaticNavigation, OutdoorUseStaticNavigation and so on. How the device recognises what setting it may use at the moment? Or there are some "hidden switch" between Vehicle and Outdoor modes? And responsible for what line GpsEnableVTGmessage is?
//Cheers, Victor
Currently Online: jg_the_Prophet
