510 won't connect | General 510 610 710 | Forums
510 won't connect
January 20, 2012
1:22 pm
lostnfound
Forum Posts: 14
October 15, 2011
5017sp_Permalink sp_Print
Thank you both for the response, I do appreciate it, it seems to have worked. Take care.
Bill
January 19, 2012
9:53 pm
Hoyks
Forum Posts: 6
January 15, 2012
5006sp_Permalink sp_Print
Jaker wrote:
What OS are you running?
If it is Windows, did you check Device Manager for any errors in Portable Devices or USB controllers?
Did you try a different USB port on your computer.
I had this error once with a thumb drive (Windows 7)and found an error in Portable devices- right clicking on the problem device and uninstalling it, then rebooting solved that particular problem for me.
Jaker
I used to get the same issue with my Triton 400 on occasion. Device manager was how I fixed it too. Unplug the GPS and delete the drivers from the computer, then plug it back in and it should reinstall it's self.
January 19, 2012
6:51 pm
Jaker
Forum Posts: 56
January 1, 2012
5005sp_Permalink sp_Print
Jaker
January 19, 2012
6:17 pm
lostnfound
Forum Posts: 14
October 15, 2011
I try to connect my 510 to the pc, while using vantage point. When i connect the GPS, and hit the connect to pc option. My computer reads "external device malfunctioned" (not recoginized) Any ideas on what is going on here?
Guest(s) 2
