Battery bleed in vehicle power adaptor | Bug Reporting | Forums
April 15, 2012
4:09 am
Forum Posts: 1547
5854sp_Permalink sp_Print
Now that is interesting, because the one that we get here is the straight USB plug.
S/N: 28B3800612200
P/N: 44221000000800
Wonder if there is a difference in the quality? also I wonder how the heck we can test it?
The adapter in the photo came with the 'Magellan Premium Car Kit for iPhone'.
I did not order it separately from Magellan.
The Magellan adapter I did order from Magellan is straight & also works with no problems.
Plus two generic adapters I have also work fine.
April 14, 2012
7:56 pm
Forum Posts: 91
5852sp_Permalink sp_Print
I have the straight version. I noticed the product photos show an angled connector.
April 14, 2012
4:37 pm
Forum Posts: 256
5851sp_Permalink sp_Print
Peter,
They are a little hard to get at, you may find it easier to cannibalise an old device and measure from the back of the socket. Link to wiring schematic below;
http://pinouts.ru/SerialPortsC.....nout.shtml
April 14, 2012
2:57 pm
5850sp_Permalink sp_Print
OK - I have a volt meter. Do I touch the outside of the connector with the red probe and earth the black?
btw - my friend believes that his vehicle adaptor doesn't work properly either.
April 14, 2012
10:08 am
Forum Posts: 256
5845sp_Permalink sp_Print
Peter,
I’m using the straight plug one with no problems; you could have a faulty one or an issue with the vehicle connection. Check that you are getting 5V under load, 1A maximum.
April 14, 2012
9:36 am
5844sp_Permalink sp_Print
S/N: 28B3800612200
P/N: 44221000000800
April 14, 2012
7:57 am
Forum Posts: 1547
5842sp_Permalink sp_Print
I just went out to the truck to check, I'm using the Magellan adapter that came with the 'Magellan Premium Car Kit for iPhone'.
This adapter has a right angle usb plug.
This is the adapter I'm using;
April 14, 2012
7:49 am
5841sp_Permalink sp_Print
...I used my 710 in my truck all day, every day on the 6 day drive...and changed the Powerex 2700 mAh rechargeable batteries once in six days!
Were you using the Magellan power adaptor or another power source?
April 14, 2012
7:17 am
Forum Posts: 1547
5840sp_Permalink sp_Print
Pprass,
Which unit (model) is this happening with?
Also, if there is any interest in a USB cable that would clip onto these units and hold it in so that it wouldn't slip down or fall out. Please email me at Zukicacher@gmail.com so that I can send or thoughts on this onto Magellan.
Some kind of clip would be a good idea.
What I would like to see is the socket straight like on the GC, not at an angle like the 510/610/710 is.
April 14, 2012
7:12 am
Forum Posts: 1547
5839sp_Permalink sp_Print
I have never had the batteries bleed off while the usb plug was hooked up.
Right now I'm in a motel in Yemassee, South Carolina on my way home to Boston from Florida. I used my 710 in my truck all day, every day on the 6 day drive from home to Port Saint Lucie, Florida, I stopped to get over 150 caches and changed the Powerex 2700 mAh rechargeable batteries once in six days!
The usb socket in my 710 has become a little loose but I have had no problems with it.
April 13, 2012
11:07 pm
5823sp_Permalink sp_Print
The units that my friend and I use are the 610 and the 710.
I'll send you an email.
April 13, 2012
10:42 pm
5821sp_Permalink sp_Print
April 13, 2012
6:39 pm
Forum Posts: 673
5815sp_Permalink sp_Print
Pprass,
April 13, 2012
4:55 pm
Forum Posts: 91
5813sp_Permalink sp_Print
No issues with my 610. I have used the both a Garmin and a Magellan adapter. They both work fine.
The windshield mount from Magellan is a bit annoying though.
April 13, 2012
3:46 pm
5812sp_Permalink sp_Print
No we don't have a problem with the connection - they are both very tight and the power icon is on all the time (well every time I look at it in any case)
I am interested in trying other power sources like David has mentioned to see if it still happens.
April 13, 2012
1:24 pm
Forum Posts: 421
5810sp_Permalink sp_Print
It's easy to see if the connection is good... the USB Power icon appears instead of the battery gauge and the backlight stays on all the time. I was thinking the same thing with the Energizer NiMH batteries I was using, which are pure garbage, but haven't had it happen with the latest set I bought.
April 13, 2012
1:04 pm
Forum Posts: 256
5809sp_Permalink sp_Print
I have had this problem with my previous 710 and there were two causes.
1. The USB socket/plug becomes a loose fit and the USB cord would drops down a bit and interrupted the connection. Trips on rough road caused it to happen quickly.
2. The USB socket in the unit developed excessively movement and the electrical connection to the PCB parted. Before it parted completely I could move the USB cord and the connection would come and go.
In both cases the charge icon would disappear while I was driving and if I didn’t notice it the unit of cause was running on batteries.
April 13, 2012
10:08 am
Forum Posts: 673
5807sp_Permalink sp_Print
Also to add to it, I also use the USB cable with a Duracell USB Charger/Battery and I have the same out come. I toss the USB Battery in my back pack and it runs the GPS for hours and hours and then when I need to I disconnect it and the unit always has its charge - but again this is not the actual car adaptor...
April 13, 2012
10:03 am
Forum Posts: 673
5806sp_Permalink sp_Print
I don't use the Magellan Car Adaptor, but I do use a regular USB cable with a cheap $1 adaptor that I bought off of eBay and I don't have any problems with it. There have been times when my GPS is reading yellow on the power meter and I plug it into my 4 wheel drive and head out and use it for hours in the truck and when I disconnect it always reads right where it was or higher than when I plugged it in - so no, I don't see this problem. However, I will say that this is with my 710, because it is normally the main GPS that I use. I haven't tested it with GC, 110 or 310.
April 13, 2012
9:10 am
A couple of us have become suspicious of the car power adaptor - we don't think it actually SAVES "AA bateries in the device while connected"!
We have the GPS in the car for quite a few hours when we cache (we need to travel long distances for our next nearest) and we find that the batteries are "used up" as we only get a couple of hours use after a long drive.
This is so for the 610 and the 710.
Anyone else have this suspicion?
phild31: 1547
David: 673
denisetdoris: 421
S!G: 280
ShortcutHicksy: 256
jmebd: 190
Caotix: 141
Members: 1569
Forums: 43
Topics: 990
Seriesaym, Rikmotu, SergeyGok, Barmanc, VirgilTracy, Phil, Tanikam, enniself48, TiramanA
Administrators: JungleGhost: 283, Mike: 25
Battery bleed in vehicle power adaptor | Bug Reporting | Forums — 1 Comment
